Motor balancing
WHat oz size are the 302s. I talk to a guy and he said to check if my bolck is for the 50oz balancing. Im not for sure if the 302s were ver 28oz, but my block is a remand, that came from a 92. it had XXX in the valley if that help any info.
I guess im just asking could it be possible that im battleing a weight balancing prob with my vibration.
because iv change both balancer and flywheel and still getting a vibration form the motor. Im not sure what crank is in it, iv got a stock 88 crank in the garage.
Can you switch the balances from 50 to 28 oz
thats what i thought. i guess im just going to have to tear it done and check it out. o well i need to smooth my bay and hide some wires anyways. might do a cheap build thread shortly guys
That sir, is going to depend on how much extensive port work that is going to be done. I have ported on quite a few heads and different makes from ATV's and VW to SBF & BBC heads. It is going to depend on how much you want to remove out of the runners for how much or how hard it is going to be.
logan409
Sep 26, 2015 07:43 PM
