Thoughts ?
Old Mar 20, 2009 | 07:34 PM
Explosive's Avatar
Explosive
Default Thoughts ?
http://store.summitracing.com/partde...5&autoview=sku
Input ?
And, it seems most cost with a gasket. Should I just use the gasket, or should I put some right stuff on the cover, then put the gasket on that ?
Or should I toss the gasket, put the right stuff on the cover and seal it ?
Old Mar 20, 2009 | 08:34 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I'd use a rear girdle cover instead of that, as for cover, you can do either, with or without sealer on the gasket, or just use sealer and no gasket, i'VE DONE IT BOTH WAYS BEFORE
Old Mar 20, 2009 | 08:53 PM
Explosive's Avatar
Explosive
Personally I would like to just use the gasket with nothing else, obviously that'd be the most simple and easy way of going about it, but I also want it to seal well, so if the gaskets are crap, I would like to know as I only want to do this once.
Races are on the 25, don't think I'm running, but the car is going to be there.
EDIT: April 25, not this must.
Old Mar 20, 2009 | 09:58 PM
86HOGT's Avatar
86HOGT
I've never used a gasket nor have ever seen any one use one. For some extra cash you could get a girdle cover.
Old Mar 20, 2009 | 10:16 PM
Explosive's Avatar
Explosive
Those girdles are pissing me off.
I've rebuilt a Chevy 350, and I'm twin turboing it myself. And yet I'm second guessing putting those damn support studs in for the girdles....
Old Mar 20, 2009 | 10:29 PM
mjr46's Avatar
mjr46
I run a gidle with no issues, been on the rear for 3 years.......Right stuff will be fine in place of a gasket
Old Mar 20, 2009 | 10:32 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I used a gasket that came w/ my cover when Mike and I did the gears. Trick flow cover, no issues
Old Mar 20, 2009 | 10:48 PM
Explosive's Avatar
Explosive
Alright then a couple more question.
pro, when you guys did your cover, did you just use the gasket alone ? and thats holding up fine ?
second, if I get a girdle, would I be ok installing the cover torquing it down, then screwing in the support studs, and only going until they touch the caps ?
third, I need to seal the threads on the studs right ? suggestions ?
and last, on the trick flow and ford racing ones, they have a drain and a fill plug, where do you fill up the girdles at ? The fill plug, or the fill plug on top of diff itself ? It seems if you fill it from the cover it obviously would hold less fluid. Also, whats better, the trick flow or ford racing one?
Old Mar 20, 2009 | 10:57 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yeah, just the gasket
Install the cover to torque specs, then I think the girdle bolts were like 10 ft#'s
Yes, seal the girdle bolt threads from the inside, mock up the cover so the bolts will just be touching the caps, then add the thread sealer
I used the top fill hole of the cover
As far as the cover, matter of preference I guess. Mike had the trickflo and was happy w/ it. So I bought that one.
Old Mar 20, 2009 | 11:18 PM
mjr46's Avatar
mjr46
your beating yourself up to much over the 10 ft lbs that those studs are putting on the caps, it won't harm them, if it did, I'd of had bearing failure awhile ago.as well as others who use such products, follow instructions and be on your way with the rearend girdle
