new toys!! just thought i'd share
Old 04-02-2009, 12:01 PM
crueheadstang87
crueheadstang87's Avatar
what are the specs on that cam
crueheadstang87 is offline
Old 04-02-2009, 12:06 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Basic Operating RPM Range: 1,800-5,800
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
Lobe Separation (degrees): 114
FivePointOhh is offline
Old 04-02-2009, 12:18 PM
AutoPartsCorp
Banned
AutoPartsCorp's Avatar
nice cam
AutoPartsCorp is offline
Old 04-02-2009, 12:56 PM
FivePointOhh
in limbo
i certainly hope so, should sound pretty aggressive.
Old 04-02-2009, 01:59 PM
USMC1775
USMC1775's Avatar
What are the heads? not E7s right?
edit : nvm I just saw your other thread
USMC1775 is offline
Old 04-02-2009, 02:10 PM
FivePointOhh
in limbo
yea, they're '66 289 heads that've been worked over.
Old 04-02-2009, 02:15 PM
cch
cch's Avatar
Hey bud, make sure to fill us in on your numbers once you get everything slapped together. I bought the same cam a couple weeks ago for my h/c/i swap but I opted for the 112 lobe instead. Good luck with the build.
cch is offline
Old 04-02-2009, 02:21 PM
FivePointOhh
in limbo
i plan on going nitrous so thats why i got the bigger LSA and the longer exhaust duration.
you got the lsa 112 264/270 right?
hopefully i get it together someone time but the weather has been either really cold or super chitty outside.
Old 04-02-2009, 02:23 PM
cch
cch's Avatar
Nope it's still 270/276, same as yours.
http://www.compcams.com/Cam_Specs/Ca...csid=1060&sb=1
cch is offline
Old 04-02-2009, 02:42 PM
FivePointOhh
in limbo
so do you already have 1.7 rockers? is that why you got that one?
Quick Reply: new toys!! just thought i'd share
