A/C issues
Old May 2, 2009 | 02:10 PM
lafd5246's Avatar
lafd5246
Default A/C issues
So, my A/C only worked on high and switched to defrost when I accelerated. I swapped out the blower motor resistor and A/C check valve on firewall and now all fan speeds work, but air will only blow through defrost vents no matter where the dial is. Any ideas?
Thanks,
JC
1990 GT hatch
Old May 2, 2009 | 02:43 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Either a bad vacuum canister or a vacuum leak in the hvac system
Old May 2, 2009 | 02:59 PM
86 5.0L's Avatar
86 5.0L
+1 i had the vacuum line from the vacuum tree disconnected and would do that
Old May 2, 2009 | 03:12 PM
lafd5246's Avatar
lafd5246
Thanks a bunch, I'll look into that
Old May 2, 2009 | 03:24 PM
lafd5246's Avatar
lafd5246
PS: I it located in the fender?
Old May 2, 2009 | 03:27 PM
86 5.0L's Avatar
86 5.0L
above the master cylinder is the vacuum tree
Old May 2, 2009 | 03:37 PM
lafd5246's Avatar
lafd5246
Cool thanks, by the way, I just got the car and have a Chilton's on the way so I shouldn't be buggin' with too many stupid questions for long.
Thanks for all the help in the meantime.
JC
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
