e303 cam...
Old Jun 3, 2009 | 07:35 AM
1fast5OH's Avatar
1fast5OH
Originally Posted by busheymotorsports
so, the big question is...what do I need to do to get the more aggressive idle like his cam? Is it a timing issue? What should I have the timing set at? I appeciate all of the help...I am new to this Mustang thing
what is your car idling at? if it idles at 1k rpm's you wont really hear the cam. i had an e cam in my car before i got the trickflow and it had a fairly rough idle. the timing was set at 10 degrees base timing from the factory to run on 87 octane. i think if you run 13-14 degrees base timing you have to run 91 or 93 octane. i dont know much about speed density though
Old Jun 3, 2009 | 09:25 PM
shawnk007's Avatar
shawnk007
what kinda exhaust system are each of you running? and is it possible your is just idling higher than his?
Old Jun 4, 2009 | 10:12 AM
PJC Racing's Avatar
PJC Racing
If you are just looking for sound, pull a vacuum hose.
Old Jun 4, 2009 | 07:35 PM
mustangsneverdie's Avatar
mustangsneverdie
here's an E-cam idling around 900-1000 rpm
http://s339.photobucket.com/albums/n...nt=Jake002.flv
Old Jun 5, 2009 | 07:09 PM
Joel5.0's Avatar
Joel5.0
I really doubt you have an E-303 in a SD system w/out any complains about idle or A/F control at idle. The E-303 will lower vacuum at idle (@750 rpm) to ~12" Hg..... way too low to the ~15" needed for the idle not to go too rich.
Old Jun 5, 2009 | 08:16 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
e cams....pewwwwwwww
Old Jun 17, 2009 | 02:37 AM
quack44's Avatar
quack44
in response to the sound video. that e-cam sounds kinda lopey sounds good to me it must be that 110 lsa
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
cema93
Aug 10, 2015 09:35 PM
Redneck1465
Aug 8, 2015 10:39 PM
mustangfan305
Aug 7, 2015 11:09 AM
