Headlight switch replacement
Old Jun 12, 2009 | 04:24 PM
steve58's Avatar
steve58
Default Headlight switch replacement
So I got my new headlight switch and tried to remove the old one,,,
Does the dash trim piece that it mounts in have to be removed? or can it be replaced from the outside? You know pull the switch out and unplug the old and plug in the new?
Old Jun 12, 2009 | 06:41 PM
1988TTOP's Avatar
1988TTOP
u have to take out the plastic around the gauges and the switch will come out the back
Old Jun 12, 2009 | 06:55 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
The switch comes out from the front on mine. There are a couple of small tabs that have to be depressed and it pops out.
Old Jun 12, 2009 | 07:58 PM
steve58's Avatar
steve58
Does this change from year to year? I'm still waiting for my service manual,,, been 3 weeks,,, they say 2 more weeks,,, its coming from "Books 4 Cars".
I got the original owners manual in 1 week for $40.
Old Jun 12, 2009 | 09:12 PM
87GT Drop Top's Avatar
87GT Drop Top
It should look like this from the side. See the circled areas? You need to put a thin blabed screwdriver in there and press those tabs in. You can do one at a time starting from the top. You push a screwdriver in there and press the tab in (see pic #2). While doing this you pull outward on the switch at the top (see pic #3) keeping pressure on it until you pop the bottom on. I couldn't have 2 hands on the switch and take the pictires so I had to do it this way. Keeping slight pressure on it will hold the top one out so you can depress the lower one and release that side of the switch. Picture #3 also shos you how it looks after you release both of them. The other side is still locked in. You need put the screrwdriver either on the side or the bottom, depending on what works, and slightly pry while still pulling on the outside with your right hand. (see pic #4 & #5). It should pop out. The wires should stretch out far enough to unplug it plug in the new one. Then snap it back in by starting with the inside of the switch and rock it to the outside and you will hear it snap in. Good Luck
Old Jun 12, 2009 | 09:16 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
they should pop out, mine do
Old Jun 13, 2009 | 11:46 AM
steve58's Avatar
steve58
Thanks 87,, for the detailed directions and photos! I;m sure this will help lots of people in the near future,
Thanks to the rest of you guys also.
Steve
Old Jun 14, 2009 | 05:48 PM
87GT Drop Top
Steve
No problem, you're welcome.
Granatelli Sales
Jan 20, 2020 12:34 AM
cbird1177711
Sep 3, 2015 08:43 PM
5.0 kevo
Sep 3, 2015 06:24 PM
whatsup62
Sep 3, 2015 01:38 PM
amandahchase
Sep 3, 2015 10:09 AM
