What will it run?
Old Jun 14, 2009 | 06:32 PM
mikekx65's Avatar
mikekx65
Default What will it run?
With my current setup ive ran the best of a 13.07@107 in the 1/4. That was leaving off the foot brake...since then i have installed new axles so i can launch my C-4 off the trans brake. The mph suggests that my ET should be in the high 12's since ill be lowering my 60ft. Now with that said i will also be installing a wet nitrous setup and eventually plan on running a max of a 150 shot. Now with being able to launch off the TB and having the 150 shot what do you guys think i will run?
Old Jun 14, 2009 | 06:38 PM
mustangsneverdie's Avatar
mustangsneverdie
mid to high 11's on slicks
Old Jun 14, 2009 | 07:19 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if you can drive 11's easy
Old Jun 14, 2009 | 07:20 PM
NoGo95GT's Avatar
NoGo95GT
With the 150 shot, mid 11's should be attainable. Are you currently running a dry set-up? What are your mods?
Old Jun 14, 2009 | 08:21 PM
mikekx65's Avatar
mikekx65
Nope not running a dry setup im N/A as of right now.
Current mods:
Stock bottom 302
Edelbrock upper/lower intake
512" Lift cam
GT-40 heads
Full MSD ignition
24# inj
BBK long tubes
BBK off road H
CAI
underdrive pullies...No ac,smog etc....
C-4 trans w/3000 stall and manual reverse VB with TB
3.73 gears
27x10 slicks
I also have some work done to the suspension like control arms welded torque boxes drag springs and a airbag on the pass side.
Old Jun 14, 2009 | 09:59 PM
mjr46's Avatar
mjr46
^^^just go run it, there's not substitute for the actual process, you can wonder and guess all you want, but in the end that's all it is
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
