EEC Connector (OBD1 Hook-Up)
Well, I managed to pick up 2 codes via jumping with a test light. Then my persistence to get my scan tool to work paid off and I found 2 more minor ones.
KOEO
11 : System Pass
66 : Mass Air Flow Sensor Circuit Below Minimum Voltage
91 : Bank 2 Oxygen Sensor
KOER
21 : Engine Coolant Temp Out of Self Test Range
With the exception of replacing my oxygen sensors, how should I fix the other problems? New ECT and clean MAF? Or replace MAF?
Thanks.
KOEO
11 : System Pass
KOER
Thanks.
1. Clear codes first and rerun a KOEO to make sure they were cleared.
2. Start engine and make sure coolant temp is above 160°F.
3. Rerun a KOER and check what codes show up.
Code 66 is a memory code, disconnecting the MAF engine running or starting the engine with the MAF disconnected will cause that code to be stored by "operator error".
Running a KOER with engine at op temp, will confirm if codes 91 and 21 are real failures first, this will prevent you throw $$ at problems that may not be solved by replacing parts, or problems that do not exist. Just a thought. LUK
