power loss at 4k
power loss at 4k
hey MF! i just bouoght a fox yesterday and i took her out for a lil spin to see what it was all about. good stock power i guess (but not near enough ) but anyway, when i floor it, it pulls until 4k RPM then it completely drops off! wtf?! i just wanna know whats going on...maybe not a problem per se but i am curious why there is such a steep decline in power. lemme know guys thanks!!
^^^^^^^^^^.....there alot of things that'll cause that and generate such symptoms, Op run a koer test and look for codes, if none come up, run a fp test with a gauge and if that yields nothing, after thatif your car has a maf try cleaning it
"Op run a koer test and look for codes, if none come up, run a fp test with a gauge"
"after that if your car has a maf try cleaning it "
sry u lost me there. koer? fp? im assuming u mean hook an OBD reader to it for codes then do a fuel pressure test? as for cleaning the MAF, ive heard just hit the wire inside with some brake cleaner, dont actually touch it. is that right?
awesome guys thanks. i just moved so didnt have internet, sry this response is so delayed. i am going to do plugs, wires, cap rotor, coil, oil change, trans flush, fuel filter, suspension lube, regluing the damn rearview mirror on!!, all in progress,
ill let u guys know if that does it.
whoa! u scared me with all that jazz.....could u break that down for me. lol does this make the car unsafe to drive as far as the engine is concerned? is it normal? come on lemme get some answers from your freaky as avatar. lmao
