roller rocker help
Just make sure you don't use stock valve covers and make sure the springs are capable of the 1.7s.
I had to grind part of the stock valve cover sidewall away to make the scorpioni 1.72s fit, and also had to remove the oil baffle under the filler neck. In the end the valve springs weren't up to 1.7 snuff. The scorpions seem pretty bulky compared to other rockers, luckily they are aluminum and are not too heavy.
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
JDWalton
Sep 24, 2015 08:47 PM
