Random Beeping sound
Old 08-19-2009, 08:58 PM
5.0stang.ryan
5.0stang.ryan's Avatar
Default Random Beeping sound
I just recently removed my gauge cluster to install a aluminum bezel. When i got everything back together and working i now have a random beep beep beep noise coming from the radio area. It never did this before. I was really low on gas so i figured it might be the problem but sure enough it isnt. I have removed it before and never had this problem. It only beeps when the engine is running. When i go drive the car it stops after a few seconds and does not come back. Then i turn the car off and start it again and the problem is back and it will keep beeping until the car is driven again. Does anyone have any idea what this would be caused by? It did remove the light from the cluster that shows the airbag sign because it has been flashing ever since i got the car? The more i think about it i think it might be the problem. Let me know what you think
Thanks
Ryan
5.0stang.ryan is offline
Old 08-19-2009, 09:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it's the air bag module, if you removed the bulb in the cluster for the air bag light or it is burned out, that is the noise, check the bulb or light and see if it lights up with the key in the on position
mjr46 is offline
Old 08-19-2009, 09:04 PM
mustangsneverdie
mustangsneverdie's Avatar
stick the light back in and see if it stops.
mustangsneverdie is offline
Old 08-19-2009, 09:27 PM
mjr46
mjr46's Avatar
it will^^^he removed it so he didn't have to watch it flash
mjr46 is offline
Old 08-19-2009, 10:15 PM
tohoopty
tohoopty's Avatar
put bulb back in.close the thread
tohoopty is offline
Old 08-20-2009, 07:17 AM
Tony71502
Tony71502's Avatar
So how do you eliminate the AIR BAG light AND the beeping noise... without having the air bag system installed? Replace the bulb with a resistor or somthin?
Tony71502 is offline
Old 08-20-2009, 12:35 PM
mjr46
mjr46's Avatar
you don't understand what he want's, I do...he pm'd me and FYI putting the bulb back in will not stop the flashing light he wishes to not see......pulling the bulb and unplug the module = prob solved AND FYI I will close thread when and if I see fit
mjr46 is offline
Old 08-20-2009, 01:11 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
Glad you asked that, my dad's car does that annoying beeping noise. I can fix now.
TrimDrip is offline
Old 08-20-2009, 01:58 PM
Tony71502
Tony71502's Avatar
So if you pull that blue module out from behind the glove box and also pull the air bag light bulb out... there will be no light or beeping noise?
Old 08-20-2009, 05:28 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Affirmative!!
PRO50SC is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Random Beeping sound
