First post after being away for more than a year= pics
Hows it going guys ive been away from the forums for more than a year and just finished a completley new suspension and brake setup. Overall the swap was a complete NIGHTMARE. I got a wrong set of spindles, wrong set of springs, calipers without brackets followed by 2 sets of incorrect brackets, a bad brake hose, a bad set of rear calipers, 2 sets of incorrect banjo bolts, and the best part 2 bad brake boosters. Most guys know what a pain it is to put in a bigger booster imagine having to do the job 3 times. Anyway onto the pics. Since the last time the car was together i have added:
93 Cobra brake booster
93 cobra master cylinder
MM 3-2 port conversion
wilwood adjustable prop. valve
03/04 dual piston front calipers
13'' front and 11/65'' rear drilled/slotted rotors
Rear disk conversion using NRC brackets and fox legnth axles
95 front spindles
MMR front coilovers with QA1 12-225 springs
Lakewood 70/30's
MM C/C plates
Rear sportline springs
Pro3i/J+M weight jacker control arms
17x9 FR500's on all 4 corners
245/45/17 summitomos on the front
275/40/17 mickey thompson ET streets rear
I also got a porter cable 7424 and used poorboys polishes and now the stock 1991 paint looks better than most new cars on the dealer lots
95 front spindles
Lakewood 70/30's
MM C/C plates
yes i plan on getting the car to the track asap. And yes i know nobody believes its original paint but the car only has 72K on it and me and the previous owner kept very good care of it. Thanks for the compliments guys
