rear end
Old Sep 17, 2009 | 07:03 PM
1988TTOP's Avatar
1988TTOP
Default rear end
so i am goin to look at a rear end on sunday and the guy said it has 4.10s and a rebuilt trac lock is there a way to know if the rear is good without it bein in the car
Old Sep 17, 2009 | 07:09 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
pull the cover off of it and see what it has. I have seen many people get ripped off on rearends.
the axles shouldn't move no more than a 1/4 inch in and out.
I have seen people that can check for slack and tell you what the tolerance is. I am not that good.
Old Sep 17, 2009 | 07:31 PM
1988TTOP's Avatar
1988TTOP
ok he said it has new brakes and longer wheel studs
Old Sep 17, 2009 | 07:56 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
sounds okay, most people that I have seen get ripped were buying rear ends with spools in them.
Old Sep 17, 2009 | 08:01 PM
1988TTOP's Avatar
1988TTOP
ok would it be stamped on the gears what it is or would it be easier to just spin it and count how many time the axle moves
Old Sep 17, 2009 | 08:07 PM
Bubba 95SN's Avatar
Bubba 95SN
Take the cover off look. Count teeth on gears divide one into the other. Will be able to see if anything is broken. Take dial indicator check backlash. Run magnet in bottom see if there is any metal .
Old Sep 17, 2009 | 08:10 PM
1988TTOP's Avatar
1988TTOP
ok also would u be able to tell if they make noise or anything
Old Sep 17, 2009 | 08:11 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you won't be able to tell if it makes noise, stuff like such I don't spend alot on so if it is bad, you won't take a huge hit
Old Sep 17, 2009 | 08:15 PM
1988TTOP's Avatar
1988TTOP
well he wants 250 for it i am talkin to him about trading a motor that needs rebuilt or m stock rear
Old Sep 17, 2009 | 08:22 PM
mjr46's Avatar
mjr46
go for it then
