Aluminum Driveshaft comparison/advice
Is anyone running the ford racing aluminum driveshaft m-4602-g? if so did you do a weight comparrison? pros/cons? i know its not necessary but i have found a good deal on a slightly used one, if i do purchase i will be putting in a new joint. thanks jay
just grab it. they are good and reduce vibrations as well as lighten it up. the stock driveshaft is kinda heavy and the aluminum one is much lighter. it will also free up some rotational mass so technically you can accelerate a little faster but u most likely wont notice that
If you do get the Aluminum DS you'll need these U Joints.
http://www.summitracing.com/search/?...=pcn-254&dds=1
Galactic
04-29-2019 02:56 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Luke9222
10-22-2015 11:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
