any input here?
Old Nov 16, 2009 | 11:22 PM
5.8 notch's Avatar
5.8 notch
Default any input here?
I know this should be in the 351 section and it is but with no answers so i thought I would try it here hoping a few guys can chime in with some info
I have tried to find answers or suggestions from several sources with no luck,I currently have a 393 windsor motor with TFS high port cylinder heads and a TFS r lower intake with the R long runner upper,comp cams hydraulic roller 274 and 288 at .006 ( can give you full specs if required) Im running 80lbs injectors and a 75 mm throttle body and kooks 1 7/8 long tube headers with a tko 600 and a snow water/meth injection.Compression is 8.5 to 1 eagle H beam rods,eagle crank,main girdle and malhe pistons and 1.6 comp cams roller rockers.
I also have a vortech V1 T-trim race m supercharger installed,now mind you the car is all fresh and motor has yet to be fired,I currently have a 77 tooth crank and a 30 tooth blower pulley with the previous guy said he was pushing about 18lbs of boost on his 331.
I would like to be in the safe pump gas area for street driving and would like to know what amount of boost would be appropriate for my application for for it to be safe and not required race gas.Also would like to know what pulleys I could run to get me into the 10 to 12 lbs boost range I would like to stay with my cog set up if possible and would like to know what pulleys I would be required to run to get into this boost area.I also realize that its impossible to determine exact numbers based on this info but I would like a ballpark number to start with.
thanks
Tivo304
Aug 28, 2023 12:19 PM
jma2
Jul 10, 2023 01:00 AM
Dokilar
15
Oct 16, 2015 08:13 PM
guitarman376
Sep 30, 2015 05:54 PM
lmurf60
Sep 24, 2015 10:07 PM
