Blue smoke... Rings OR Valve Seals??
Old 10-12-2009, 03:53 PM
F150 StrokerCobra
F150 StrokerCobra's Avatar
Default Blue smoke... Rings OR Valve Seals??
i havent cheked the compression yet.. im gonna chek it today or tomorrow but i took a vid of it smoking.. the pass. side smokes worst than the driver side.. it was smoking before but way less.. now its getting worse and worse.. i talked to the engine builder he said the valve seals went on very tight and they where not the correct ones he gave me the correct ones to order now if thats the case
0.500 guide
11/32 stem + .010
and i found plugs 1.4.6.8 Wet.. ( oil )
before only plug 4 was wet..
ow and btw the engine did not lose power!! but still im going easy on it and not driving it anymore
Video is uploading..
F150 StrokerCobra is offline
Old 10-12-2009, 04:01 PM
F150 StrokerCobra
http://s198.photobucket.com/albums/a...t=MOV02470.flv
Old 10-12-2009, 07:25 PM
Bubba 95SN
Bubba 95SN's Avatar
Not the correct valve stem seals is a hint. You can always blow air into cylinder to hold valves up. Take off rockers, valve keepers, springs, and replace seals without removing heads. Then have a serious talk with machine shop that installed incorrect parts. This was avoidable.
Bubba 95SN is offline
Old 10-12-2009, 07:53 PM
F150 StrokerCobra
well i guess its the valve seals i did a compression chek and they are
1. 180
2. 170
3. 180
4. 180
5. 180
6. 180
7. 180
8. 180
already talked to them he is gonna change them for me no charge
Old 10-13-2009, 11:46 AM
F150 StrokerCobra
why is it oily in a few intake runners? specially nr 4cyl the one plug i always find with oil! its oily in there but not in the intake itself... i suspect the gasket was leaking..
i noticed something today... when cold it does not burn oil .. i drive it a little and give it a few revs let the engine warm up ( its NOT low on power i may add ) and it started smoking.. my money is on the intake gaskets.. ?
Old 10-14-2009, 12:32 PM
Bubba 95SN
Bubba 95SN's Avatar
Question. Were the heads resurfaced?( Shaved down to make flat.) You can use mustang metal type valve cover gaskets that can be reused. Clean the mess out of intake and head to intake mounting surface. Use RTV on block ends not the gasket. Follow torque sequence and specification.
Old 12-26-2009, 02:19 PM
F150 StrokerCobra
turned out to be the seals.... Teflon seals in an everyday driver is FAIL.. no i got Trickflow Viton
Old 12-26-2009, 04:30 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I've used the viton ones on all my heads
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
Dathan
10-05-2015 05:52 AM
winner99
10-01-2015 01:06 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Blue smoke... Rings OR Valve Seals??
