transmission upgrade
Old 12-21-2009, 09:24 PM
  #21
1988TTOP
1988TTOP's Avatar
ok thanks cause i think i am goin to put my kit together and try to save some money
1988TTOP is offline
Old 12-21-2009, 09:25 PM
  #22
motorman524
MF Informant
motorman524's Avatar
Originally Posted by ctgreddy
driveshaft does work fine when you put the new yoke on it, but it appears to stick out of the trans too far so i'm going to try the spacer.
Yeah sorry I didnt put those periods on the end to sound like a jerk or something. I posted that without seeing your d/s spacer suggestion(I was typing while you posted) Hope were good in the hood.
motorman524 is offline
Old 12-21-2009, 09:35 PM
  #23
1988TTOP
1988TTOP's Avatar
ok so i heard that u can use the stock bellhousing u have to drill new holes in it though is this right or no and what clutch should i buy
1988TTOP is offline
Old 12-21-2009, 10:50 PM
  #24
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Also you gotta remember ctgreddy that the sn's drivetrain is a little longer than the foxes so the spacer is more than likely not needed.
projectresto83 is offline
Old 12-21-2009, 11:11 PM
  #25
primetime5.0
primetime5.0's Avatar
you can modify the stock cross member, if not HPM has a specific crossmember, you'll need a 31 spline ds yoke, 26 spline clutch. If you get a scattershield you'll need to index it, I went with a standard aluminum bell myself, shifter if it doesn't have one, pilot bearing is the same as a t-5.. have anymore questions about it let me know
primetime5.0 is offline
Old 12-22-2009, 05:04 PM
  #26
1988TTOP
1988TTOP's Avatar
i found a used tko600 1000 miles on it zoom stage 3 clutch a fidanza aluminum flywheel the bellhousing and a pro 5.0 shifter and a frpp driveshaft for 2000 shipped sound good
1988TTOP is offline
Old 12-22-2009, 08:10 PM
  #27
1988TTOP
1988TTOP's Avatar
any1 ....
1988TTOP is offline
Old 12-22-2009, 08:38 PM
  #28
primetime5.0
sounds good, run the serial number on the trans, make sure its what the owner says it is
Old 12-22-2009, 08:42 PM
  #29
1988TTOP
1988TTOP's Avatar
ok where do i go to run it
what would my t5 setup be if i rebuild the trans i have a king corba clutch has like 50 miles on mgw shiftr 50 miles flywheel bellhousing stock ds be worth
1988TTOP is offline
Old 12-22-2009, 08:44 PM
  #30
primetime5.0
I believe tremec's website give the #'s on the trans to see what it is
far as your stock stuff I'm kind of a cheap *** I'd say like 600 for all of it
Quick Reply: transmission upgrade
