5.0 engine combo, I need input on this
Old Jan 7, 2010 | 11:26 AM
  #21
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
Originally Posted by rdavin622
If im dropping this amount of coin on parts then the stuff is going to be new. It's just how I think. Its like buying a used engagement ring for a woman. most of them wouldn't like that. They want new stuff from jareds
you'll learn...
i had no problem with my used parts that i put on in my bolt on days, before i (stupidly) decided to built my 357W out of all brand new parts.
honestly, polish up or paint used parts and only you will know they are used. buying used parts could be the difference between having or not having that money left over to buy the parts to beat that pesky LS1 'maro down the road...
Old Jan 7, 2010 | 11:31 AM
  #22
motorman524's Avatar
motorman524
MF Informant
I agree that things like heads should be bought used. However certain parts should be bought new.
Old Jan 7, 2010 | 11:56 AM
  #23
AdderMk2's Avatar
AdderMk2
Banned
wanting a new intake over a used intake is retarded.. it has no moving parts. so unless the PO screwed it up somehow, then its just a dirty version of a new piece!
Heads are kinda hit or miss. I would never buy a set of used heads without putting my hands on them. end of story!
rockers, lifters, pushrods. i'd go new all the time.. always, forever!
electronics.. maf, injectors, etc... used is perfecty ok!
TB, another piece thats really hard to mess up. It can only be junk if modified, or if it was junk from the get-go
Old Jan 7, 2010 | 01:18 PM
  #24
rdavin622's Avatar
rdavin622
I ordered my trick flow stuff this morning. I do appreciate all the responses but I only need to make 300hp to be happy. I'm running stock aode and rear end and just can't afford to upgrade everything to support 400 or more hp. thanks alot guys!
Old Jan 7, 2010 | 01:29 PM
  #25
motorman524
MF Informant
What kit did you go with?
Old Jan 7, 2010 | 03:27 PM
  #26
rdavin622's Avatar
rdavin622
I went with the track heat package, the silver one. I'm just going to rebuild the stock block and put this stuff on top of it. My goal is right around 290-300rwhp with a tune. Thats all I expect out of it anyways
Old Jan 7, 2010 | 05:14 PM
  #27
sn95_331_GT_ yellow
get a set of small TFS dome pistons while youre in there to bump the compression to around 10-10.5:1. might as well...
djbigskrilla
Sep 20, 2022 01:04 AM
waid302
Sep 14, 2015 11:19 AM
Evilwilly
Aug 25, 2015 10:30 PM
12bigredstang
Aug 25, 2015 04:58 PM
05slpGT
Aug 12, 2015 02:32 PM
