E brake question
Old Jan 10, 2010 | 12:47 PM
blueboosted95's Avatar
blueboosted95
Default E brake question
I have a 90 lx and it has the sn95 rearend with disk brakes, how do i convert my ebrake to work in my foxbody? Also is there anyone who knows the correct axels to put in my rearend due to the fact that my passenger side wheel sticks out a quarter inch more than the drivers side! thanks in advance
Old Jan 10, 2010 | 01:00 PM
Tony71502's Avatar
Tony71502
The proper way to convert the ebrake is by replacing all three cables. The two new large cables run in the same location as the old cables. The third cable that is attached to the ebrake handle gets replaced by a cable that has a threaded rod on it. The threads on it go through the stock equalizer after you enlarge the hole. The equalizer is held on by two nuts. You can use the nuts/threaded rod to adjust the ebrake. You will have to get these parts from a Ford dealership or from Ford racing. I will dig up the part numbers in a little bit.
The spiral spring in the ebrake handle gets disabled by cutting it. You weld the pawl to the ratchet so it is essentially one piece.
Here are some pictures that hopefully will help. If you have any more questions let me know. Mine works perfectly.
Don't mind that poopy stock driveshaft... it's aluminum now.
Old Jan 10, 2010 | 01:09 PM
blueboosted95
that will be awesome thanks tony u can check my new ride out if ya want in the new members area, looks kinda like yours
Old Jan 10, 2010 | 01:53 PM
motorman524's Avatar
motorman524
MF Informant
Thanks for that info man, bookmarked
Old Jan 10, 2010 | 03:38 PM
ALMOST STOCK's Avatar
ALMOST STOCK
You can find all 3 cables at Summit Racing
Center adjustable cable - M-2810-A
Rear cables (for 87-92) - M-2809-A
1993 rear cables - F3ZZ-2A635-A
Old Jan 10, 2010 | 06:55 PM
Tony71502's Avatar
Tony71502
Thanks for posting those part numbers. As he said, the two long cables on the 1993 are different than the rest of the foxes, so be sure to get the proper part.
Old Mar 17, 2010 | 12:08 PM
motorman524
MF Informant
n/m,
figured it out. got them ordered
Old Mar 20, 2010 | 05:08 PM
motorman524
MF Informant
Got mine done today. woot!!
Old Mar 20, 2010 | 06:03 PM
symonds86's Avatar
symonds86
thats one of the next things on my list to
Old Mar 20, 2010 | 07:02 PM
motorman524
MF Informant
It was really easy to do. It took me so long to get out and do it because I was dreading it.
Tivo304
Aug 28, 2023 12:19 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
