1983 t top mustang gt
So here is my idea i am getting a 1983 mustang gt 5.0 high output with the 5 speed borg warner transmission
I plan on making this a 11 second street car my first ideas are this
get a trick flow stage 1 camshaft
accufab 70 mm throttle body
cold air intake
steeda option 2 exaust system
frpp aluminum driveshaft
adding 3.73 gears or 4.10
cold air intake
Didn't the 83 have a carb? Did you change the motor to a late model EFI? Is the motor fairly new? If not, and it is time to do a rebuild, it is hard to go wrong with cubic inches. Add a stoker kit. Watch the compression ratio if you plan to add boost later.
gets some nice sticky tires too, suspension etc.
I personally like to start with the suspension, brakes and chassis first on a car, so when I add the power, I know it can take the extra abuse and the car can handle...
Diode Dynamics
28
05-26-2022 12:02 PM
