Pro comp Heads?
Old Jan 21, 2010 | 07:18 AM
stanglover0526's Avatar
stanglover0526
Exclamation Pro comp Heads?
i am looking to buy some heads for my 91 gt and ran across this company through jegs. I havent heqard much about them and wanted to find some people running them.Here are the specs i got off the site.
Procomp Aluminum Heads For Small Block Ford 210CC intake Runners And 60CC Combustion Cambers There Heads Are Ready To Bolt On with 3/8 Studs And Guide Plate The Springs are Good up to 600 Lift Solid Or hydraulic Cams
Aluminum Cylinder Heads Feature-
Hardened Seats
Bronze Valve Guides
High Grade Aluminum
Multi-Angle Seat Design
Available Complete or Bare
Available fully CNC Machined
Designed Performance Valve Springs
Advanced Port Design for Greater Flow
Combustion Chamber: 60cc
Intake Runner: 210cc
Intake Valve: 2.02"
Exhaust Valve: 1.60"
Spring Pressure Closed: 140 lbs. @ 1.800"
Spring Pressure Open: 325 lbs. @ 1.225"
Retainer Material: Steel
Valve Seal Material: Viton
Valve Guide Material: Manganese Bronze
Valve Job: 3-angle
Old Jan 21, 2010 | 02:15 PM
mendez4047's Avatar
mendez4047
dont do it. use the search feature on this website and you will see bad results...you get what you pay for...
Old Jan 21, 2010 | 11:14 PM
luckythirteen13's Avatar
luckythirteen13
they are garbage. get yourself a good set of afr's or TW heads. if money is tight, head over to corral.net and get a used set
Old Jan 22, 2010 | 06:41 AM
stanglover0526
Thanks guys
jerrytubes
Oct 23, 2015 12:11 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
junior04
Sep 28, 2015 10:53 AM
