c clips vs c clip eliminators
hey guys, I have a few questions about C clips and C clip eliminators.
I am in no position to upgrade the fox right now, but this info will help me ensure I buy the right parts in the future
first, where are the C clips located in the rear end?
how do C clip eliminators work?
Which one is not allowed in NHRA events?
what will be best for a car that will mostly be on the street, and rarely see the track?
do I have to buy specific axles for C clips vs c clip eliminators
will either work with a rear disc brake setup?
I heard one type can cause the axle to walk out of the housing? is this true?
do I have to modify the axle housing with C clip eliminators?
thanks guys, I save all the threads I make in this section so I have a little guide book to go by when ordering parts/working on the car
The are in the diff where the axles go through the side gears
The axle is pressed into the eliminator, like a ford 9" set up if you're familiar.
No idea
The stock c-clip set up.
Nope, same axles will work w/ either
I have heard that the eliminators will not work w/ rear disk.
It can happen, anything is possible
Yes and if you don't do it right they will leak and you could ruin the housing.
No idea
C clip elims let the rear end work the same as a c clip setup. The only difference is whether the axles are held in place by a c clip, or a bearing with a retainer that's pressed in place. All the old Ford 8 and 9 rears were non c clip.
C clip setups can cause the axles to walk in and out of the housing some, but that's normal and there is a tolerance range. That MAY be a problem on a road course/autox though if you're at the limit of the allowable tolerance, since it can cause the rear wheels to walk back and forth and will change the rear wheel tracking when you corner, which may or may not effect the vehicles handling(depending on the extent of walk and how the suspension is set up).
You can get brake kits that will work with c clip elim setups, but the reality like was said, if you're going to see very little track time, it's not worth the hassle and investment.
The primary advantage to a non c clip, is in the event of an axle breaking, it doesn't come out of the car(along with your wheel).
C-Clip eliminators eliminate the C-Clips that retain the axles in the tubs. if the axle brakes half way down the shaft with clips it can allow the wheel and axle to come out of the axle housing. Buy put eliminators on the axle which are pressed on the end axle and then the eliminators bolt to the housing so if the axle brakes it will stay in the housing and not fall out. the eliminator take place of the factory bearings
like said the 9in ends are the best way to go but can get $$ at some places. I have a set of strange eliminators on our street car though with there 33 spline axles and they use a bigger bearing made for the street and work very well and I have a set of Moser on my other car if I had to do it again strange would be on both cars. You will hear the ends leak but I have yet to have a issue with them after 2 years of street driving and a friend has had no issues with his after 6 years. Yes you can run rear disc with the Mosers not real sure about the strange I didnt look into it. after a 10.99 I think you need to move up to C-Clip eliminators I think is the time. NHRA and IHRA rules. You will need to cut 1/4 off the ends of the housing if I remember right just take your time and make sure it is a straight cut. if you go with the 9 ends you should have the housing straightened while you are doing it also.
thanks guys. I highly doubt this car will see 10 second times, dont think I can get that out of the 306 I plan on building with an HCI and a Kenne bell.... while retaining A/C, cruise, full interior and possibly my smog (depending where I move and live after I graduate)
I do appreciate the info and helping me build the car I have dreamed up in my head.
Im in the same boat kind-of. Im switching to 31 spline and 4.88's, and Ive been reading and reading about which eliminators leak, etc. It seems that Strange and Moser have both worked well and been leak-free for alot of people.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
