performance chip
Old Feb 27, 2010 | 12:53 PM
94vigstang5.0's Avatar
94vigstang5.0
Default performance chip
im looking to put a performance chip in my 94 5.0 5speed stang and im low on funds so dose anyone know of a cheap but good performance chip.
i was looking at the Surge chip what do you think?
Old Feb 27, 2010 | 01:12 PM
primetime5.0's Avatar
primetime5.0
The only chips worth anything are the ones that are burnt for a specific application
Old Feb 27, 2010 | 01:27 PM
94vigstang5.0
well im looking to get more hp but the surge chip can do 2 things from what i read it dose the hp or it can do the 4-9 mpg better, i have a bone stock stang looking to beef up in time
Old Feb 27, 2010 | 01:58 PM
luckythirteen13's Avatar
luckythirteen13
LOL at 4-9mpg. thats the most rediculous thing ive ever heard. you wont get any gain in mpg and maybe 5hp from a chip. dont believe everything you read.
its custom chip from a dyno tuner or nothing. and you dont even need that untill you have done h/c/i
Old Feb 27, 2010 | 03:28 PM
stang8689's Avatar
stang8689
i tried a hypertech years ago it made it slower
Old Feb 27, 2010 | 05:16 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Save your money
Old Feb 27, 2010 | 05:26 PM
AdderMk2's Avatar
AdderMk2
Banned
I'll sell you my SCT chip.
Old Feb 27, 2010 | 08:11 PM
nitrous_bob's Avatar
nitrous_bob
all they do is advance timing... do it yourself for free
mm & ff used to have the 10 free things or some **** always posted
basically if your all stock do this...
1) drop the silencer.... most likely already done
2) advance the timing to about 12* btdc
3) k & n filter or cai
4) dump excess weight
5) get gears and tires
gears code is in the door tag under "ax"
m= 2.73
z= 3.08
e= 3.27 (aod's only)
go for the 4.10's and get a sticky tire... you'll feel like you bolted on 100 hp
Old Feb 28, 2010 | 08:36 AM
93hatch306's Avatar
93hatch306
like everyone has said so far, don't waste money on a chip. bump the timing yourself and add an adjustable fuel pressure regulator. my car actually needed less fuel pressure than the factory setting when it was still stock. you really don't need a chip for a H/C/I install either...I have a Holley Systemax intake, 70 MM TB, Stage 2 Trick Flow cam (.542/.563 lift, 224/232 duration), Stage 2 ported Trick Flow Track heat heads, 30 lb. injectors and a Pro-M mass air meter. No chip in it, and it's my daily driver....makes 305 RWHP (it's only a naturally aspired 306) and gets 20+ MPG.
jwog666
Dec 27, 2021 08:09 PM
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
