turbo 347?
Old Mar 26, 2010 | 02:31 AM
nascrchi's Avatar
nascrchi
Originally Posted by luckythirteen13
with the right heads youll make over 400bhp n/a
wow!!! 302 or 347? how much to get that done??? haha
Old Mar 26, 2010 | 08:35 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
on a 302 you can make over 400rwhp, my build will be damn close on my 306. it'll be a custom solid roller set up with a lightweight bottom end and high revs...not your typical SADI hyd cam set up...but it can be done
Old Mar 26, 2010 | 11:19 AM
hypertruejedi's Avatar
hypertruejedi
so do you think that this turbo idea would get me to or over 400bhp?
Old Mar 26, 2010 | 11:39 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
turbo on a stock 302 with enough boost should do that
Old Mar 26, 2010 | 12:06 PM
FivePointOhh
in limbo
i think you need to scrap the turbo idea, sell your heads and cam. start over with a better platform.
Old Mar 26, 2010 | 12:46 PM
luckythirteen13's Avatar
luckythirteen13
exactly. i can say from experience that even with boost, if the heads are too small for the motor itll still be a turd
Old Mar 26, 2010 | 01:34 PM
hypertruejedi
great.. so what size heads/cam/carb should i go with? ive been told by several people that my intake will work given the right support, so what do u guys think?
Old Mar 26, 2010 | 03:41 PM
FivePointOhh
in limbo
vic jr. is a nice piece. contact jay at camshaft innovations and he'll hook you up with a proper set up. he can get you anything you need. heads, cam, carb, timing set, lifters...anything.
Old Mar 26, 2010 | 04:50 PM
luckythirteen13
after you pick out your heads, have a cam custom made for you. the price is comparable to off the shelf cams but the gains are much better
Old Mar 26, 2010 | 05:58 PM
uedlose's Avatar
uedlose
the heads will work just fine with the 347 and boost you will reach your goal easy + some. While the heads may be a bit small they will work just fine the turbo is gone to push the air through the intake side without issues and the exhaust no matter what it flows is gone to run into a big cork anyway as soon as it hits the turbo. I think the compression is a bit high for my liking but like said it will work with the right tune. Hell as far as that goes those heads with some port work will go 9s without issues Lee Rutter did it many years ago way back in the hay day of the 5.0.( showing my age again ) I don't know how much boost he ran but he did it. Boost is a wonderful thing build it and have fun.. like Mike said a stock 302 with enough boost will make 400 HP
