Bolt stuck in hood
Bolt stuck in hood
I have a bolt stick in the threads where the hood bolts onto the hinges. If I turn it, the nut turns in the hood. What is my best option here to get my hood on? I could cut that off and redrill a hole elsewhere but how am I going to get a screw to stay in the fiberglass? Can I actually buy those nuts that are fitting into the hood?
This,from my experience, is a common problem with fiberglass/carbon fiber hoods. Does it have brass inserts for the threads? if it doesn't, get the other bolt out and step 1^. if it doesn't, someone was a dumbass and crossthreaded/torqued too much while threading...
