cam bearings wiped away
don't spend a whole lot of money on a rotating assembly in a stock block. If it were me, I would try to get by with polishing the crank. If the crank needs to be turned, I would look at a different crank then. I would go with arp rod bolts. Don't be a redneck and put them in with an impact, have the machine shop work them. Or if you find a deal on an I-beam forged rod with bolts do that. I would say invest in a light piston but, with enough boost, you will probably be happy enough.
sounds good . so i have like 800 for pistons , rods and crank, the stock crank is good to keep right? i found forged i beam rods and pistons for about 600. that seems like a good price. is their a company i could call that packages this stuff? i am new to mustangs i built two turbo 240sx's .- thaks
As long as it doesn't have to be turned, I wouldn't hesitate to run it. I don't like the idea of bigger bearings on a boosted motor. Stock motor I would run a .10 under crank in a heartbeat but, not with the pressure a boosted motor will put on it.
Only pistons I ever bought for a 302 besides the ones for my 393 was a set of DSS pistons. They were the bottom of the class of what they built. And they were VERY heavy. It was only 330 for those and a set of eagle I-beams and arp rod bolts off ebay so i can't complain really.
A friend of mine is running BRC pistons and they seem to do good. Ross and JE of course will do good. Some people say good things about the Probe and Mahle too.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
