Intake install?????
Old May 2, 2010 | 10:14 PM
g3mustang's Avatar
g3mustang
Default Intake install?????
Hey guys I'm about to do a cobra intake install... Any suggestions would be great. Gasgets and things like that. Also stupid question do I need to run an egr spacer... Will it mess up my throttle cable if I don't... Also if you guys know of any write ups that would be great...
Thanks
Old May 2, 2010 | 10:29 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I always take the corner bolts out first because they will be the ones most likely to break off. I would hit them with a hammer first to help break them loose. Use black rtv around the coolant passages and about a 1/4" bead on the front and back of the block. And put a set of heads on if using the stock e7s now.
Old May 2, 2010 | 10:39 PM
g3mustang's Avatar
g3mustang
Arv around coolant passeges under the gasgets???? And rtv front and back intsead of gasget... What about the egr spacer???
Old May 2, 2010 | 10:47 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
yeah on top and below the gasket. If it does what it is designed to do, it is not needed. It is insurance though from having the labor into having to tear it all back off again if it does leak. Yes, throw the gaskets away, same deal. You would want to put rtv on it anyways on both sides if you did use it. Still no reason to use it though.
The egr, I can't tell you anything other than delete and see if it will work. If it doesn't, just take a piece of aluminum, drill some holes and cut to fit.
Old May 2, 2010 | 11:00 PM
g3mustang's Avatar
g3mustang
Ok cool thanks for the help any other tips??? Are the heater hoses hard to get off??
Old May 2, 2010 | 11:06 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I don't think I took them off at the heater core. It has been a while since an intake change.
Old May 3, 2010 | 01:26 AM
crusin92red5.0's Avatar
crusin92red5.0
The cobra intake has a built in egr spacer. The gt40 doesn't. So in your case you will not need the actual spacer. The heater hoses can be hard to get off if they've been on there awhile.
Old May 3, 2010 | 07:09 AM
g3mustang's Avatar
g3mustang
I know it has a egr built in but I was just making sure for the throttle cable length..
djbigskrilla
Sep 20, 2022 01:04 AM
Granatelli Sales
Jan 20, 2020 12:34 AM
cbird1177711
Sep 2, 2015 04:12 PM
SYNY5TER
Sep 2, 2015 01:35 AM
