Throttle Position Sensor Settting
Old Jun 1, 2010 | 01:07 PM
TTaylor's Avatar
TTaylor
Default Throttle Position Sensor Settting
I've heard you can set throttle position sensor but wasn't exactly sure how?.Also how do you have your mustang performance mods listed when you post a new thread or respond to other people thread ?
Old Jun 1, 2010 | 02:44 PM
00limited7's Avatar
00limited7
This is the instructions that I used to set mine. May have gotten this from this site not sure where it came from. Here you go:
Let me explain what the throttle position sensor does and how it could tell the computer any information.
To get a better sense, remove the TP sensor from the throttle body completely. You will see an end sticking out simliar to a flat screwdriver. That will fit into the throttle position sensor. As you push the throttle , it turns. When it turns it changes the voltage that the sensor reports. So if your sensor is set too high, it reports that the throttle is somewhat pressed (to an a small extent but it is still incorrect). When it shows it higher, it tells the computer "Im at this point of the Wide open throttle cycle." Imagine the sensor is reporting equivelant to the pedal being pressed 10% down, but it's actually at 5%. What does it do when it reads higher? It dumps more fuel because you need more fuel to accellerate. Or it could read the other way around. You could be at Wide open throttle (the pedal is being pressed to the floor) but it only reads you are around 3/4 to the floor. You are telling the computer where you are at and it adjusts how much fuel to add (simply put).
When you adjust the idle screw you are opening/closing the throttle butterfly more. Well guess what is sitting on top of the the butterfly? Your TP sensor. So when you adjust the idle screw , you adjust the voltage of the TP sensor because it turns it more one direction that it was already calibrated at. So when you adjust one, you should adjust the other, making sure though the TP sensor is always set last!
Ok. First of all you set the TPS when the car is off and the keys are up (radio comes on). Make sure your voltage meter is DIGITAL , not the sweeping kind. Set it to DC voltage reading, not AC or anything else. Push a sewing needle through the center of the green wire coming off of the TP sensor.You are going to be hooking up the red (positive) wire to the needle that you pushed through. I like to put the black wire (ground) up the the bolt that holds the TP sensor onto the throttle body. Ok by now you know what wire needs to checked and where to hook up your ground. Read your meter. It can read anywhere from 0.00v to 3.00 depending on how messed up it is. As described earlier the meter determines the voltage by how much the butterfly of the throttle body is opened because it rides directly on top. So we must turn the throttle position sensor to match the voltage we need (it is a small fraction of a turn but it still moves some). You are trying to set it at 0.98 volts !
To turn the throttle position sensor we need to loosen the two bolts that hold it. This allows us to turn the sensor clockwise or counter clockwise. To figure out which way it needs to go you must know where it currently is. If it's too high, you need to lower it. Turn it one direction, if it goes even higher or lower than you need you must turn it the other direction. It can be slightly tedious , turning and checking the voltage. It helps to have a buddy hold the wires on the correct spot and you turn it as necessary so you can read it in realtime. Once you have it set at the right spot tighten the bolts down. Recheck your voltage to make sure it didn't move. If the voltage changed loosen the bolts slightly and try to nudge the sensor so you can still move it but it won't move when you tighten it.
After that you are set. You can start charging people good money to tune their TPS.
Old Jun 1, 2010 | 03:05 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
tps should be set anywhere from .8 -1.0 vdc
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
