Failed smog test
Old Jun 4, 2010 | 12:56 AM
StevoX1's Avatar
StevoX1
Default Failed smog test
So its about time to re-register the 93 fox 5.0, so i take it to get smog tested, test only, and the stang doesn't pass passed every category but registered too high for the NOx section..
Talked to my local mechanic and he said the main 2 causes are cat's and egr.
I got new cats installed when i got my exhaust done not too long ago so i dont think its those bad boys, so i went to inspect the egr. Took my CAI off and oh boy was it dirty in there, so i cleaned it out and cleaned my air filter while i was at it/re-charged it.
I'm taking it back in the morning to get it re-tested to here's to hoping it all goes well.
Just wanted to share my grief with ya'll
Old Jun 4, 2010 | 01:16 AM
luckythirteen13's Avatar
luckythirteen13
did you do a basic tune up before taking it in? spark plugs, fuel filter, adjust tps, clean maf, set timing to 8* base, etc?
Old Jun 4, 2010 | 01:22 AM
StevoX1's Avatar
StevoX1
just replaced the fuel filter a couple months ago, going to get some MAF cleaner in the morning, and ive never tinkered with the timing so that should be set, ima double check that in the morning tho
Old Jun 4, 2010 | 01:32 AM
luckythirteen13
stock timing is 10*, setting it down to 8* helps with smog
Old Jun 4, 2010 | 06:47 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
PLease do not create double threads OP!!!!!!!!!!!
jwog666
Dec 27, 2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
Teddi
Sep 29, 2015 12:24 PM
GLOCKer
Sep 28, 2015 07:36 AM
