proform 67015
Old Sep 14, 2010 | 08:24 PM
nitrous_fed_03gt's Avatar
nitrous_fed_03gt
Default proform 67015
i searched the board and didnt find what i was looking for. does anybody have good step by step install instructions for this fan? maybe including how to properly remove the factory belt fan as well for an 89 fox. im sadly very poor with wiring. the instructions that came with it are kinda a blur to me, but i dont want to pay somebody to install it cause im sure that would cost more than i paid for the fan itself. i just dont understand wiring diagrams well. like hook into this fuse and that fuse. wish i could just hood into the negative and postive sides of the battery. and its the little things i dont get like why didnt the kit come with the fan already tightned down? i mean its only a little allen screw but just seems silly. and i dont get where exactly the sensing probe is even at in the kit have no idea what it looks like. i bought it from jegs. thanks guys
Old Sep 14, 2010 | 10:04 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
The factory fan itself I can help you with. You want to leave the belt on and the bolts in the fan. Take a large wrench. I believe a 1-5/16 is the size. Or it will work anyways. Place the wrench on the fan clutch and hit it with a large hammer. If you beat on it a bunch of times it should come off. If not, use an air chisel....at least that is how I have always done it.
As far as the wiring, we need to know how you want the fan to cut on. Switch, ac, temp sensor....
Edit: Now that I think about it, I don't think you have to use the hammer and wrench to get the fan off. Just unbolt it from the pulley and put the nuts back on. I took mine off two weeks ago but, have took so many off since then, I can't remember.lol Anyways, if you do, that above is how. Seems like I didn't have to on the mustang 5.0 but, I did on the 2000 explorer motor going in.
Old Sep 14, 2010 | 11:18 PM
nitrous_fed_03gt
I want it to come on with the ac, and also with the thermostat. It has an adjustable feature on it where it can come on between 180-240. Obviously I would have it set as low as it can go
Old Sep 14, 2010 | 11:51 PM
nitrous_fed_03gt
I'm jus gonna have to tough it out and use the crap instructions it came with. So can anybody tell me what the most accessible low amp 12 volt power source is that I can splice into? Guess I couldn't just use the positive side of the battery like I'm going to do for my high amp 12 volt power source. Thanks
Old Sep 14, 2010 | 11:52 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
your temp sensor you are using, it has one wire grounded, one wire to a 12+ power source and what is the other wire? a ground or 12 volt wire for the fan. Or do you have a one wire temp sensor with a ground only?
Old Sep 15, 2010 | 11:41 AM
nitrous_fed_03gt
i believe the other wire is there to splice into the ac wiring so the fan turns on with the ac maybe?????
YoungStangsMan
Sep 5, 2015 07:01 PM
tom50
Nov 29, 2006 02:56 PM
OneFine89Mustang
Aug 27, 2006 05:59 PM
OJMiles
May 2, 2006 11:14 PM
meiguoren33
Apr 26, 2006 11:30 PM
