IS MY CAR TO HIGH IN TIME?
My 87 gt mustang that is a 5-speed car with 4.10 gears under it. Ive noticed when going up a good size hill in 5th gear the valves chatter sum. Also when im getting in to at higher rpms it has a chattering noise sum times. Could this be do to car being to high in time? If so what do you suggest the timing to be set at? Thanks in advanced!
could also very well be that you have an exhaust leak at your headers. When it leaks, it makes a very similar sound almost like a valve tick that increases/decreases with rpm. But its nothing you can feel obviously its only audible.
never by ear..... get a light or borow one from the local parts store.
make sure you do it correctly, the SPOUT needs to be popped out b4 you adjust it...then put back in after.
b4 you start it up your gonna need to clean up the balancer marks with sanpaper then wipe it off and fill the lines in with white chalk or white crayon. then wipe off the excess so the lines and numbers are bright white. you want the scale that goes from 0-20 NOT 10-0
i'd set it at 12*
i'd set it at 12*
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
