electrical problems
Old Oct 29, 2010 | 07:03 AM
03svt4life's Avatar
03svt4life
Exclamation electrical problems
I recently bought a 93 hatch, every now and then turn signals wont work, rear defroster, hvac controls wont turn on(backlighting works), aftermarket radio wont turn off when you turn car off(separate problem i am sure), I have read about wiring issues with the headlight switch, not sure if that would cause other problems, Any ideas on a direction to go? cuz after few min everything will work
Old Oct 30, 2010 | 08:16 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Tear apart your steering column and check out the wiring and plugs on all your switches. The old ignition switches tend to melt or crumble causing elec issues.
Old Oct 30, 2010 | 02:52 PM
holyshift's Avatar
holyshift
^^^^Boom,check your ignition switch,I had the same problem with my turn signals,turned out the ignition switch plug was loose. As far as the other stuff,you may find it in the column as well.
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
