First engine build
Old Nov 9, 2010 | 11:28 AM
67mustang302's Avatar
67mustang302
Adjustable pushrod length checker. You can buy one from Summit etc.
Old Nov 10, 2010 | 09:17 PM
AntiRiceRacing's Avatar
AntiRiceRacing
Will i need one of these as well? http://www.summitracing.com/parts/PRO-66790/
Also after i adjust the push rod checker, how should i measure it to get the most accurate reading?
Old Nov 10, 2010 | 09:24 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
no need for a mock up rocker arm, I use the rocker itself I intend to use for mock up, a adjustable push rod comes with a predetermined min max length, the comp cam one I bought screwed all the way in is 5.800 and all the way out 6.800, there is a dotted line on each half and one complete revolution is .050 iirc on mine, so no need to have a tool to measure it, just know it's closed length and as you screw it out count the turns and know how much each revolution adds
Old Nov 10, 2010 | 09:37 PM
AntiRiceRacing
Thanks thats very useful info. I seen there are many different length ones, which do you recommend for a 351w? (im guessing 351w's use longer push rods?)
Old Nov 10, 2010 | 09:40 PM
mjr46's Avatar
mjr46
yes 351's will use a longer one............can't say I know the answer to that one since I haven't built a 351, just many 289/302/347's
Old Nov 10, 2010 | 09:45 PM
AntiRiceRacing
I guess ill just do a little searching and take a educated guess, and your suppose the measure the length when the lifter is off the lobe im guessing?
Old Nov 10, 2010 | 11:39 PM
mjr46's Avatar
mjr46
when it's on the base circle meaning the flat
Old Nov 12, 2010 | 07:14 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
if you get the one that MJR said (same one i have), just look at the line and count how many turns it is. each rev. = .050". any other one will have to be measured with a set of verniers to accurately (i know i dont need to say it, but DONT use a tape measure...)
FWIW, the pushrods i measured up my truck engine were 6.250" so expect something in that range.
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
