i run one on my carb motor and the only reason i run it is because it only needs one wire to run.and no im not a chevy guy.i was going for something simple and trying to use as little as wires as i could.and fyi you cant use a stock hood with it.
running hei on mine for the same reason. Ran both the large and small, was able to use the factory hood, but have to run a small element. I can't imagine the large one would fit on a gt40 intake, but the small one with a separate coil shouldn't be any different...............
