puzzled vacuum question
Old Jan 12, 2011 | 08:39 PM
Venomantidote95's Avatar
Venomantidote95
Default puzzled vacuum question
Ideas on low vac at idle with 114* lobe seperation all my homework suggest it shouldnt be an issue. Any insight?
Old Jan 13, 2011 | 09:01 AM
ProTrickVic's Avatar
ProTrickVic
what are you considering low vac? what does the cam card say you're supposed to pull? did you degree it in?
Old Jan 13, 2011 | 04:51 PM
Venomantidote95
2 in hg at 1000rpm yes it degreed at 110* as required ill look on my card and get back to u.
Old Jan 13, 2011 | 05:47 PM
Venomantidote95
Ok couldnt find the card so I called comp he said easy 10in at idle. Went over vlv preload and vac leaks I have replaced ever hose.
Old Jan 13, 2011 | 06:06 PM
68CSTANG's Avatar
68CSTANG
Sounds kinda stupid, but have you checked the gauge on any other cars? I have had 3 different vac gauges take a dump. Good luck!
Old Jan 13, 2011 | 08:38 PM
67mustang302's Avatar
67mustang302
Does the car idle fine? 2" at idle and there's no way it'll idle at 1k rpm. Many racecars with 4-5" idle vacuum idle very rough at ~2k rpm.
Check the gauge on another car, and also make sure it's actually on a manifold vacuum connection, and not some form of ported vacuum.
Old Jan 13, 2011 | 09:02 PM
Venomantidote95
Ok the gauge was my first thought its good I dont have good brakes o installed a reservoir and still no vac for brakes over 8 in duringl normal cruising I have 10 12 in but idle 2. An efi car can idle any rpm pending tuning software. Most between 850/950 I bumped it to 1k n higher to see if it helped. I have moved the line from right behind the tb to plenum to the firewall port all the same result. Thats why im asking for fresh ideas.
Old Jan 13, 2011 | 09:39 PM
67mustang302
Check to see your IAC position. If the IAC is way open to idle it, then you might get low vacuum, but that indicates something is seriously wrong that would force the IAC to fully open just to get the engine to idle.
Old Jan 14, 2011 | 08:30 AM
ProTrickVic
sure you have the rockers set right? when i was first learning i had the rockers far too tight and the engine wouldnt run right....because of this all my readings were way off including vac....
Old Jan 14, 2011 | 08:39 AM
Venomantidote95
Preoad is .025 for the arms. How do u check iac position without xray vision?
