I found this odd
Old Jan 30, 2011 | 07:37 AM
91Vert's Avatar
91Vert
Default I found this odd
Since I got the 91 the car seemed to run "hot" for the first cycle of the tstat. I thought it was just the gauge, but I figured I'd change the tstat out. I change it out and find all kinds of rust debris in the housing.
If you look in the radiator the same thing is going on in there. The thing that got me is that when I checked it when I got it, it was green and rust free. Now it appears as water and rusty.
I flushed it all out with the water hose and put in some fresh coolant. I'm guessing that the rust did something with the tstat or it was just bad, because now it doesn't do the "hot" cycle. It stays dead center of the normal in the temp gauge. Before it would go to the one above it and then come down.
Now, all is well. The guy I got it from said it had a new motor in it, so I guess he could have just thrown 90/10 of water/coolant mixture in there, and I've had it running long enough to get some corrosion. We are pretty far south. Just thought I'd share.
Old Jan 31, 2011 | 08:40 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Corrosion is pretty normal. Especially when normal tap water is used. Nothing to get your panties in a bind over
Old Jan 31, 2011 | 09:23 AM
5.0kid's Avatar
5.0kid
the guy prop put brand new stuff in right before you came over that way it looked legit
Old Feb 1, 2011 | 05:54 AM
91Vert's Avatar
91Vert
I'd have to agree with you. It had a "new" thermostat in it, too Either way, it's all good now.
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
Dokilar
15
Oct 16, 2015 08:13 PM
KingRando
Oct 2, 2015 08:06 AM
Drastang
Sep 30, 2015 03:48 AM
