trans is finally in!
They tell you it when they buy. I agree with this if its custom, because what people do is they go and call bullet cams or etc. like I did for my motor and they get them to go ahead and take time to look at your combo and maxamize a cam spec for it, then they would tell you and instead of going to buy through them because they are about 200 more expensive then say comp. you then take the specs, call comp cams and have them make that cam for less. Puts people out of buisness real fast. Its not just cars either happens with my dad at work as well. spends days researching a job site for a concrete mix that needs to be made for the area, weather, type of use, etc. and once they get the mix design they go behind his back and go to another company that is cheaper just so they can get the concrete for the job site. I like the fact that bullet doesnt give out cam specs until you purchase the cam from them and money is recieved because then you know they took the time to desgin a bad asz cam, or in k webbs case a bad *** converter
Well I more so meant certain builders I have heard that won't give out specs period.
Don't wanna drag names through the mud that I haven't have first hand experence with, but thats more so what I was talkin' about.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
