scanner?
Old Mar 16, 2011 | 02:20 PM
Venomantidote95's Avatar
Venomantidote95
Default scanner?
Will obd2 pocket scanners pull codes from an SN obd2 port reading obd1 systems. I know an 8500$ genie system will but not sure on a obd2 pocket.
Old Mar 16, 2011 | 06:42 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
niether will pull codes from the blank connector, the connector was fitted on all sn-95's as the same harnesses were used for v-6 and v-8 models, the v-6 models were obd 2 complient but the v-8's used the obd 1 out under the hood
Old Mar 16, 2011 | 06:45 PM
Venomantidote95
OK that's what I needed to know! Wasn't sure if it worked its wired in!
Old Mar 16, 2011 | 07:34 PM
mjr46's Avatar
mjr46
I know the obd 2 connector in them has wires going to it but iirc they don't lead to the ecm, never torn the dash apart on one but my guess is they'd lead to an open connector
Old Mar 17, 2011 | 01:51 PM
Venomantidote95
ok thanks!
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
1TUFF302
Nov 5, 2015 04:02 PM
Big Al's 03
Sep 16, 2015 07:31 PM
rksnow1
Sep 14, 2015 08:46 PM
