Brake hose?
Old Apr 5, 2011 | 01:33 PM
mustangGT86_05's Avatar
mustangGT86_05
Default Brake hose?
I am ready to install the rear end on my mustang, but I have one snag slowing down the whole process. The hose on the rear end was cut, which it was junk anyway, but on the axle housing theres a junction and the hose bolts to that with a banjo bolt.
I figure no problem, I'd hope the drum rear end I'm about to take out would have a similar set up but I am wrong. It turns out on my mustang the center hose connects to the chassis junction with a banjo bolt, then on the differential housing it has a junction where 2 lines go in.
So, my question is, does anyone know of a brake hose where I could use a banjo bolt on both ends? If I can find a hose like that then I can install this rear end real quick, but so far am not having any luck. If anyone knows and could on top of that supply a part number I'd be very thankful!
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
lmurf60
Sep 24, 2015 10:07 PM
