I have a 89 mustang GT and there is a ticking noise coming from one of the lower pulleys, it sound like its in the motor but if i remove the belt the noise is gone. i have smog delete and a/c delete and i know its not coming from the alternator. to me it sounds like its coming from the harmonic balancer but i have never heard one make a noise like this. there are no vibrations in the motor at all. i looked around and couldn't find a thread with the same problem any help would be appreciated. thanks
i swapped the belts and that wasnt the problem, it sounds like its coming from the harmonic balancer or water pump, it speeds up with the engine but if i take the belt of it goes away. it kinda sounds like a rod knocking but again if the belt isnt on then it doesnt do it.
