what are the symptoms of cam being over advanced?
is there a way to tell if you did not degree your cam correctly?
does low vacuum tell you your too advanced?
306,.030 trw piston w/relief cuts,1.6 rr, windsor Sr heads,springs good to .600 lift ,XE274hr,GT-40 intake,with 1 inch spacer.
or does this cam always run low vacuum?
am running around 10 to 12 inches of vacuum at idle. very good bottom end but out of steam at 58k or less.
If you read. I ask about low vacuum. I get different answers on vacuum some say it should pull at least 17 inches or more. I am only at 10 inches to 12 at best. I asked if this cam just has low vacuum. That intake is good to about 6k or less which shifting should be right at 58k or so because when you shift it's prolly higher to keep from rpm drop. I know less vacuum would be a vacuum leak. Between 10 to 15 might be over advanced timing?
ps: cam timing could effect where the power fall off is advanced to far could lower it but you've made no mention of where you set it at, if you set it dot to dot as I did with my 282 only after the degree wheeel confirmed it then you most likely are fine and I'd look else where, but did you degree the cam to check the valve events??
