Holley blue fuel pump mounting ?
Old Jun 26, 2011 | 07:39 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Originally Posted by Ze2222
Hi guys. I got some spare time so i climbed underneath and looked at where you guys suggested. To get the pump lower then my sump i'd have to use a drop bracket and also then the pump will be highly visible. I don't believe i'd like that too much.
Attached is a pic where i'd like to mount pump. Its a tad bit higher then sump though. Tell me what you guys think or what'd you do?
you don't need to get it lower, simple fact is the holley blue has plenty of suction power, there will be no issue, in theroy what has been stated is correct, is it necessary for your intended use..no, mine has been where I stated for 7-8 years and seen multiple trips to the track and on the bottle and has run 10's and never ever had an issue...bottom line is you'll be fine
Old Jun 27, 2011 | 11:21 PM
Ze2222's Avatar
Ze2222
thx you very much. I thought the pump would generate at least some suction just everyone i talk to says for it to be lower then the lowest point of your tank.
Thx again for your help.
Old Jul 12, 2011 | 03:06 AM
Ze2222's Avatar
Ze2222
well i'm back. I just mounted my holley blue and i must admit it looks good :P.
How are you guys who are running -10an lines routing them? Just with p clamps down passenger side?
Thoughts on going through interior? or would you recommend staying away from that?
Old Jul 14, 2011 | 10:49 PM
Ze2222's Avatar
Ze2222
?? anyone.
Old Jul 14, 2011 | 11:20 PM
mjr46's Avatar
mjr46
I'm running -8an and I secured mine to the existing line under the car, do not run it in the car.
Old Jul 17, 2011 | 10:43 AM
holyshift's Avatar
holyshift
^^Same,i just zip tied my line to the old fuel inj line.
1TUFF302
Nov 5, 2015 04:02 PM
9550
Oct 26, 2015 05:01 PM
TfcCDR
Sep 14, 2015 12:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
