aftermarket front suspension ?'s
ok so ive been looking at doing a coil over kit in the front. are they worth it for a street car? what kit would you recommend and ive read that you need caster camber plates, i have the steeda billet caster camber plates are these strong enough to handle the coil over set up? also been thinking about a tubular k-member and A arms which ones woould u suggest for a dd street car? thanks
thanks. wat about the tubular k-member? and what springs? i have steeda superlite sport springs and bilstien shocks and struts in it now (came in the car when i bought it). but the top coils of the front springs are collapsed on to each other and when i hit bumps they make like a rattle noise.
H&R Supersports are nice. My Eibachs sagged like a **** and the ride quality sucked. I'm now on Eibach Drag springs.
The rattling noise you hear is more likely coming from your camber/caster plates.
As for a K-member. Its not a bad thing to swap. If you want to really lighten up the front, you can run the AJE Racing K-member, which has A-Arms with spring cups. It is not necessary to swap the A-arms either. I am currently running stock arms on my car, with a QA1 K-member. After I get home I'll be switching over to some fox control arms (Don't ask), and might go tubular....
09-24-2015 09:18 PM
Ghost_Conscience
09-23-2015 02:17 PM
