need quick definitive directions
Old Aug 12, 2011 | 12:38 PM
88LXSTANG's Avatar
88LXSTANG
Default need quick definitive directions
Hey guys I come to the masses with another fuel pump question. I'm sure ill catch some flak from a few of you guys (adder), but I'm lost. My car has been sitting for a year now and I finally decided to put in a new engine. When I spun a bearing last year it would still start, when I tried to start it again the pump wasn't priming. I've searched and found all kinds of info but tracing wires and testing such has never been a strong suit. But I have the following info and just need direction on what's next. Using a test light there is power on both wires to the inertia switch, and I can hear the relay click. I have access to the pump connections and they didn't show power. If I sprayed starting fluid into the tb it would run so I know it has spark and the ecm is good. I'm leaning towards the pump being bad. What say you guys? Any help and criticism is appreciated.
Old Aug 12, 2011 | 01:27 PM
g3mustang's Avatar
g3mustang
if you didnt see power to the pump how could it be a bad pump? why not try to run a remote wire to the pump and see if it kicks on? if it doesnt then you have a bad pump
Old Aug 12, 2011 | 01:52 PM
88LXSTANG's Avatar
88LXSTANG
Is there a way to do that without dropping the tank?
jwog666
Dec 27, 2021 08:09 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
popsotto
Sep 28, 2015 06:58 AM
