trans-clutch problem?
Old Oct 10, 2011 | 03:13 PM
beaky73's Avatar
beaky73
for the love of pete, this trans will not go in!! eveytime i slide it in the throw out bearing comes off the fork... i have tried installing the trans with the clutch cable connected and disconnected... the trans goes in and the bearing moves and i get snaged on the clutch teeth... then i have to start all over... can someone tell me or point me into the right direction on how to do this.. i had it in before but the cable was disconnected so i pulled it out again.. does the cable have to connected or not? please help!!!!
Old Oct 10, 2011 | 03:20 PM
GIXER7502006's Avatar
GIXER7502006
bigger hammer lmao
Old Oct 10, 2011 | 06:48 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
the clutch cable is the last thing you put on. If you can't get it in that way get some threaded rod and use them as alignment dowels on the transmissoin so it slides in straight. Make sur eyou are putting the bearing on the fork right also.
Old Oct 10, 2011 | 08:26 PM
beaky73's Avatar
beaky73
would i be able to put the bearing on the shaft with the fork, then slide the fork onto the pivit ball in the bell housing..
Old Oct 10, 2011 | 08:37 PM
projectresto83
M.A.D. Motorsports
There should be no reason to do anything but put the bearing on the fork and then while taking your time slide the trans in a little, check the fork or slide the bearing on the bearing retainer by hand and then keep sliding the trans in more....making sure you have it in straight before you try to push it into the clutch plate and into the pilot bearing..
Old Oct 11, 2011 | 06:07 PM
Bubba 95SN's Avatar
Bubba 95SN
Is the clutch properly aligned? Tried using a transmission jack or experienced friend?
Old Oct 11, 2011 | 10:20 PM
beaky73's Avatar
beaky73
well i worked on the trans.. i went and got a new throw out bearing and i had the trans about 1/2 inch from meeting the bell housing, so i pulled the trans out a hair to spin the shaft at the tail and the whole thing slid out.. so i thought it would be easy to put it back in and so far nothing... i think the problem is that i am on my back with the front of the car on jack stands so i am pushing to high instaed of at an angle. i wish i had a friend to help.. some one to control the jack... tomorrow i will try again.. thanks for the help and do not laugh at me to much...
Old Oct 13, 2011 | 03:18 PM
beaky73's Avatar
beaky73
well, the trans is in and the car can move, thanks to Bobs transmission... i had the car towed to a shop a mile up the road and had it done.. i got to the point where i could not move my left shoulder so i gave up. in total with the tow it costed me $200... and he had it done in less then 24 hours.. he got the car last night and i got the call at 2 saying it was ready.. thanks for all the help..
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
