Vacuum Question
hey guys,where does the vacuum canister on the fuel rail hook into for a vacuum source? the intake? also there is 4 vacuum lines on the passenger side in the engine compartment right behind the strut tower they are all in a plastic plug, what are they? sorry for the odd/dumb questions thanks mike
The 3 of the 4 vacuum lines from the rubber distribution block (plastic plug) are emission related. They go to EGR Valve, Air Diverter Valve, and the Air Bypass valve. The 4 line comes from the backside of the upper intake and plugs into the rubber distribution block.
would this be the correct part to connect to the lines/connector? also i am running a explorer intake, does that have an effect on the connection to the intake? http://www.ebay.com/itm/1987-1993-MU...sories&vxp=mtr thanks for the help mike
would this be it? http://www.ebay.com/itm/FORD-MUSTANG...sories&vxp=mtr
If you have the other end that has the vacuum lines that go to the EGR, Air Bypass,Air Diverter and back of intake, then yes that is the part you need.
If this is what you have been talking about it will look like with both ends together?
