Ok so finally made some initial break in power pulls on the engine VIDEO turn spkrs ^
can't see the video because I'm at work, so I'll check it out when i get home....
but what can you do about the builder? If he kinda tells you tough luck, that's B.S. to me. I'm sure there is a ton of money in his pocket out of yours.
And whats 30hp at the speeds/traps your going for? I would imagine less then a tenth?
30 hp from a n/a engine is a lot especially at the power level im at already. When you are told we have other engines with less cam and less compression making 850 you should make that at a minimum you expect to get to that at least. Ive dumped over 15grand into this guys pocket CASH
Just watched the video, sound's good and seems to rev up very clean!
KEM Motorworks
08-14-2015 10:13 PM
