1995 mustang gt convertable
Old Dec 31, 2011 | 12:21 AM
DeathRattle's Avatar
DeathRattle
AdderMk2, wouldn't bad cats cause a CEL? And while I agree with what you're saying I was giving him advice mainly based on common engine problems that he can diagnose within 30 minutes without having to turn a wrench. Besides he also said the car will start missing which leads me to believe it's related to spark or fuel. That is why a simple check of each cylinder might give away the problem. Heck he could even run an infrared temp gun on each cylinder to see which one is off from the others. Anyway his problem seemed to me to be something engine related...
Old Dec 31, 2011 | 12:25 AM
94Blk5.0's Avatar
94Blk5.0
^ Not directly. OBD-I cars don't have O2 sensors down stream of the cats.
Originally Posted by francissanf
116k miles... but should i change the internal or external... or bolth
External.
Old Dec 31, 2011 | 01:36 PM
francissanf's Avatar
francissanf
yea I there are no loose tubes ect the vacume is good my e break is good ima change the fule filter and have my uncle take a look at the o2 if it dosent work then idk what elese to do bout it
Old Dec 31, 2011 | 01:40 PM
francissanf
and i think its a fuel problem because its only when i try to accelerate or go up hill... when im just cruising or going downhill i can pick up speed
Old Dec 31, 2011 | 05:51 PM
AdderMk2's Avatar
AdderMk2
Banned
REMOVE THE O2 SENSORS FROM THE EXHAUST
Old Dec 31, 2011 | 06:22 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
OP, you created this thread then another asking the same question, please do not creat multiple threads on the same issue, thank you, since your question is technical in nature , this one will be closed and the other in the 5.0 tech sec will remain open .
Urambo Tauro
Dec 17, 2016 03:30 PM
Roger Mabry
Jun 15, 2016 08:27 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
Lee1911
Sep 1, 2015 02:12 PM
daytooday
Aug 11, 2015 09:22 AM
