gear question
Sounds like a high 2. Something or a 3.08. Easiest way to tell is take the cover off, count the teeth on the pinion, then count them on the ring gear and divide the pinion count into the ring gear count. You can also jack the car up in the air, spin the tire one full rotation and note how many times your driveshaft spins but it isn't as accurate, it will get you in the ballpark though
i know my last car would run around 100-110mph in 4th (4.6L) with 3.55 gears and this one will do somewhere around 80-90mph in 4th also my speedo is like 8mph off at 55
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
