motor mounts
Old May 6, 2012 | 10:15 AM
majohns's Avatar
majohns
Default motor mounts
is there any advantage to swapping to solid motor mounts versus urethane mounts?
Old May 6, 2012 | 10:35 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
less wheel spin
Old May 6, 2012 | 01:59 PM
majohns's Avatar
majohns
not that i am disagreeing with you but could you explain how that would help? i am just trying to make sure i am on the same page. here is what i am thinking and i may be wrong... with solid motor mounts sub frame connectors and strut tower brace should take most of the flex out of the car and the mounts instead of the motor rocking over on revs and hard acceleration it would put that torque through the drive train. thus with all this done should put more horsepower and torque to the tires. does this make sense? am i correct?
Old May 6, 2012 | 11:34 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
You are on track with the idea. The problem with solid mounts is they are not very street friendly. They cause too much vibration.
Old May 6, 2012 | 11:45 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if it's a street/strip car, use the urethane mounts, no need for solid for such intended use.
Old May 7, 2012 | 04:46 PM
majohns's Avatar
majohns
ok thanks guys
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
